Dear sir,
I want to produce hot water using a HRSG. The HRSG should increase the temprature of water from 50C to 160C. The flow rate of needed water is high (about 1500~2000 ton/hr).
Can I use a Heat Exchanger like economiser in HRSG? In the other hand, I want to use a HRSG that produces hot water. Is it impossible and how can we control water outlet temprature?and if not, What is the method for obtaining this target?
