I am trying to get PEMAG value for a shell element in Abaqus 6.10. I understand the default is top and bottom section points. However, I am struggling to get the output at other section points e.g. mid or 3. Is there a way to do that in CAE (only top and bottom are showing when using the Results>Section Points) or I would need script to access those values at section points 2,3,4? My shell elements have 5 integration points defined. Thanks in advance.
