N G P
- May 15, 2018
- 33
Hello All,
I have been checking the interface shear strength between a precast block and the cast in-situ concrete portion above it for a gravity retaining wall as per ACI 318-14. I have a doubt about the shear strength and whether it is okay to consider section 16.4.4.1 as it is for the flexural composite members. In my case, the block is not in flexure and it only transfers shear. or should I follow the shear friction method in accordance with section 22.9 and provide interface shear reinforcement?
I was initially planning to check the shear strength without interface shear rebar.
Many Thanks
Many Thanks
