Interpart Expressions on Partfamily-Members
otsis2017
1
Hey,
I'm sending you my question because I'm sure you can easily give me an answer.
I have a partfamily with about 400 members. In an assembly I use multiple instances of the partfamily. Normally the instances are all different.
In the assembly I have some Interpart Expressions, which refer to the Partfamily members. The reference stay when I change the variant, everything okay!
But now when I change the variants so that I have one variant twice in the assembly then the Interpart Expressions of one of the members gets destroyed. I think this is because they have the same part name in this case. Is there a way to make the two or more same instances distinct?
Thank you for your reply,
best regards
Andreas
Might you be able to post an example of this problem? I'm pretty sure I don't understand the question yet.
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Product Engineering Software
Siemens Product Lifecycle Management Software Inc.
(Phoenix, Arizona)
