Is there a connection like UW-13 for direct connection of Body flange to spherical heads? 3
gh61
15
drawing, dimensions, more details ....?
Hi
Similar to the attached details
YES.
OP,
Look up Fig 1-6.
Figure 1.6 does not apply.
The OP diagram is a welding neck flange.
VIII-1 UW-13 (b)
(b) See below:
(1) Ellipsoidal, torispherical, and other types of
formed heads shall be attached to the shell with a butt
weld, or as illustrated in the applicable Figure UW-13.1
sketches (a), (b), (c), (d), and (i)
So flanged shell to head connection may not be permissible.
@ goutam
You are confused. This is a category A welded joint.
@ goutam
Can you explain more?
See UW
@r6165
Thank you for the info. Actually, it should be a type C joint. But I never handled such a joint.
@gh61
Please see the following from Mandatory Appendix 2(Flanges), Fig 2-4
This is the type of welding I am referring to:
Which clause you are referring to?
Again NO
Why don't you read the text and not the sketch?
OK I give up as you are not explaining yourself.
See also figure UW-3 on the left, the spherical head.
Try to understand about spherical head.
It is a flanged connection. So it should be type C as in the figure. Type A is welded connection. This is my understanding.
See my sketch
Please see VIII-1 MA1 Fig 1.6 for permissible types of bolted dished cover joints.
Please ignore Mandatory Appendix 2(Flanges), Fig 2-4 shown above as it is for bolted piping joints (apologies).
Once more you are wrong
IT SEEMS IMPOSSIBLE for you to understand what the OP says in his NOV 2 sketch: the body flange is a WELDING NECK, it is full penetration butt weld !
