Rocketeer3k
Aerospace
- Feb 2, 2011
- 18
Dear all,
I have a peculiar case in which the exact opposite happens from what is expected. I am modelling crack propagation using cohesive elements. In the beginning I am just modelling a mixed-mode bending test in plane strain to calibrate my model parameters. The model is bending dominated, much like a cantilever with tip-load. Trying different mesh sizes and elements for the bulk material I found the following:
1. Quadratic plane strain elements (CPE8) deliver the most accurate solution. (Closest to analytic solution)
2. Linear elements (CPE4) are softer than quadratic elements
3. With increasing mesh density the solution with linear elements approaches the quadratic solution, thus the model becomes stiffer.
This is exactly contrary to what I know, that linear elements are softer in bending than quadratic ones and that the response stiffens with mesh refinement.
Can anyone explain this?
