I have a model in which I have very high stress concentrations. The 3D model consists of fibres in a matrix. The entire top surface of the model is displaced by 0.1%. Z-symmetry is applied on the entire bottom surface, except for the middle fibre. This simulates the fact that that fibre is broken. Because of this, I have very high stress concentrations surrounding this broken fibre.
I have modelled the problem using 3D solid elements and tried both linear and quadratic elements. To my surprise the stress concentrations in the model with linear elements where higher, no matter how refined I made my mesh. I always believed that linear elements should result in the same stresses, if you just make your mesh fine enough. However, this was clearly not the case in this model.
Does anyone know the reason for this?
Best wishes,
de_yentl
Best wishes,
de_yentl
