Nov 7, 2024 #1 FrancoisY Mechanical Joined Nov 10, 2023 Messages 34 Location US Hi All, if a radius has a Max or Min radius call out, is it affected by the general tolerance table in the drawing? Thank you
Nov 7, 2024 #2 jassco Mechanical Joined Feb 22, 2011 Messages 568 Location US No. Your general tolerance table only applies to those dimensions that have not tolerance. Best regards, Alex Upvote 0 Downvote
Nov 7, 2024 Thread starter #3 FrancoisY Mechanical Joined Nov 10, 2023 Messages 34 Location US jassco said: No. Your general tolerance table only applies to those dimensions that have not tolerance. Best regards, Alex Click to expand... thank you! Upvote 0 Downvote
Nov 7, 2024 #4 looslib Mechanical Joined Jul 9, 2001 Messages 4,205 Location US Be careful using a min radius. Basically anything larger than the min is allowed. There is no control on it unlike a max which sets a limit. Upvote 0 Downvote
Nov 7, 2024 #5 y2k_o__o Petroleum Joined Nov 20, 2022 Messages 6 Location CA Call out will overwrite anything in the general tolerance table Normally I don't control fillet radius unless it's a critical feature to avoid interference or stress concentration. Upvote 0 Downvote
Nov 24, 2024 #6 ShataCastings Mechanical Joined Oct 20, 2024 Messages 30 Location US Genral tolerance = Unless specified tolerance So once you add Max or Min Radius, it was specified Upvote 0 Downvote
