Multi-engine planes ? 1
rb1957
Aerospace
CA
Can someone help me with a project ...
looking at a multi-engine plane, but I want to change out two (the outer pair) engines. The two new engines will have a different drive speed than the original. I have a propeller for the new engine (to suit it's speed) but the question is synchro-phasing. I know only enough to know what I don't know ... This is a real project and would probably engage professionally off line if there's a solution.
A thought I had was to manually adjust throttles ??
The current project is not for certification ... a proof of concept vehicle only. The final project would probably have all of the new engines. Would that be the easier way to go ??
That's the easiest way, I don't see any particular virtue in trying to synch between the pairs. Incidentally you'll need a much better audio setup than I have here to really hear the fundamentals, 85 Hz is well into the roll-off of my decent speakers, and I ain't playing crude electronic crap through them. I'll dig a gaming subwoofer out of the pile of discarded toys and see if it makes more sense.
Cheers
Greg Locock
what I meant was synch-ing 1 and 4 ... right now there's none (2 and 3 would be synch-ed by a kludge of the OEM system) ... not much thought has gone into this detail (yet) ...
I would look to see if one engine is the master. Considering 1&4 are more influential it may be one of them.
Here you are in glorious 32 bit floating point at 44.1 kHz (undocumented feature being you can write wav files in all sorts of formats, but only that or 48 kHz is actually recognized by the player. Harrumph).
so the 4 numbers in the title are the rpm errors, you have a baseline, then engine 3 out by 5, then engine 4 out by 7 , then both out. I have reduced the amplitude of the outer engines as they will be attenuated by up to 6 db compared with the inners.
Here's what i used
%User input
N_blades=[3,4,4,3];
nominal_rpm=[1900,1200,1200,1900];
disp(N_blades.*nominal_rpm/60)
harmonic_structure=[1,0,.3,0,.1,0];%integer multiples of BPF, use complex for phasing
rpm_error=[0,0,5,7]; %usually LHS will be 0
wingpos=[-7.2,-3.6,3.6,7.2];%location in m. + and - don't matter. Not used
amplitude=[1,2,2,1];%arbitrary
duration=10;%seconds
dt=1/44100.;%seconds
wavfileout='waaWaa_sin_0_0_5_7.wav';
Cheers
Greg Locock
