Queens New York showing a vent explode spewing fire. The man survives but with burns.
Any ideas on what might have caused this?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
NREL-Secondary Network Distribution Systems Background and Issues Related to the Interconnection of Distributed Resources - attached said:2.4 Secondary Grid Network Cable Protection
Underground cables connect secondary buses, moles, and crabs in the grid network system to one another. The number of cables per phase and cable size depend on the maximum possible load flow. The number of cables can range from one to dozens per phase.
Cable-to-cable limiters protect these cables. Limiters are designed for 4/0-, 250-, 300-, 350-, 400-, 500-, and 750-kcmil cables. Limiters are also available for connecting cable to bus and
cable to moles. Limiters are also included in “fusible crabs.” These limiters should coordinate with the network protector fuses and the insulation damage characteristics of the cable.
Some utilities do not use limiters for cables 4/0 and smaller because they assume that cables are small enough to burn clear.
