yes, ozone hole bad, lets in high energy radiation ... bad.
I see this story unfolding as ...
1) (just possibly) land based observations in Antarctica hint that something has changed and the amount of UV at the surface has increased. Mind you we've only been there a few decades so we don't have that much history ... maybe this is "normal" (or within normal variation) ?
2) NASA satellite later confirms that there is thinning of the ozone layer.
3) Then someone (who maybe detected molecular CL in the ozone layer) develops a theory (that this thinning is caused by molecular CL).
4) Then someone links this with CFCs (ah ha ! the smoking gun).
Of course all this could be good science, I don't know enough. But if most CFCs are from refrigerant, then I'd suspect most is in the northern hemisphere and wind patterns would make it hard to get to the south pole (because of the wind patterns around the south pole, confining the cold air). It does make me wonder.
Then new research shows that molecular CL can be produced by melting sea ice, so now there's a source in the south polar region (but not a manmade one).
Now if they can show (maybe by isotopes, like they do with Carbon) that this is due to our CFCs, then that a completely different story.
I do think we are quick to blame ourselves for things (the way we mess up the planet), and maybe this was an example of the "precautionary principle" and since there were alternatives that weren't too onerous then ok, lets ban CFCs.
