Ozone hole ? 6
rb1957
Aerospace
Apr 15, 2005
15,976
not really climate change but I mentioned it and then scratched away at the scab.
NASA data doesn't show any recovery to me ?
 https://files.engineering.com/getfile.aspx?folder=6409b661-133d-466b-a82e-5d20db168453&file=Screen_Shot_07-29-22_at_01.27_PM.PNG
dik said:
I don't have a clue about what the end result will be, but I suspect it will not be good. pipe
You don't want it to be good...
The only remaining question is, when you are expecting the worst possible outcome will you be disappointed or won't you be disappointed?
Why... I have kids, grandkids and great-grandkids, to think about. I'll be thrilled if things turn out well; I won't be disappointed. [pipe]
dik,
The problem is really only about your attitude. Fix that and the problem evaporates (faster than ever).
For the most appropriate attitude adjustment in these frazzled times, I advise a trip to Disneyland with the entire family.
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
personally I recommend Monty Python, either ...
1) from "contractual Obligations", "The Baggage Retrieval System at Heathrow", or
2) from "The Life of Brian", the closing song "Always Look on the Bright Side of Life".
Is it time to toss the Holy Hand Grenade of Antioch at this thread?
On the count of 1, 2, 3...
You are the holy hand grenade to every thread in this forum...
Nope... as long as it sort of stays on topic... to keep people informed of what's happening, just so they know what problems exist, and what possible relief there is. [pipe]
...The Sound of John Denver Being Strangled...
Tug,
And you are the Killer Rabbit(hole).
brims... can you tone it down a little bit?
Oh I am toning it down.
I could tell... [pipe]
Should have seen what I scratched out…
Was it something along the lines of "Fuck off with the stupidity?"
None of this BS has anything to do with the hole in the ozone.
I would have guessed it would be Chuck Norris that punched a hole in the sky.
It wouldn't shock me at all if Frank Dux claims that he punched a hole in the ozone layer
