bimr
- Feb 25, 2003
- 9,367
Three dwellings have been "completely destroyed"
"This explosion has affected at least a three block radius up here."
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Was this some kind of public housing project? Can't imagine anyone but the government building something so unappealing.
BGE, the nation’s oldest gas utility with origins dating to 1817, likely needs to replace thousands of miles of obsolete pipes.
Many houses in that era probably used either cast iron or "black iron" pipes set in the concrete screed or under the floor boards to pipe it internally. Often screwed joints as well.
Would be interesting to know if there was a void under the houses or not, i.e suspended floor or solid floor.
And provide service "more efficiently", read cheaper, in the process. How many times are we going to fall for that line of reasoning?
IRstuff said:True, but USPS directly charges for services, while the DoD does not.
Imagine if people saw the per capita bill for DoD's services
