Pipe Flow from resovior to machining center 1
farmENGR
Hi all,
I want to acheive a velocity of 28-32m/sec on our coolant lines to our grinding centers. We have a resovior(transor system) that pumps fluid to our grinding centers.
We performed a 'bucket test' yesterday to determine the liters/minute which is the volumetric flow rate of our oil. How can i figure out the velocity of the oil. I want it to be between 28-32m/sec.
We will pour the contents into a large measuring bucket to determine how many liters we have aquired. We filled up the bucket for one minute.
We are having our transor system re-engineered so that each machine will be able to be controlled by one pump. Right now Machine 1 and 2 flow rates are much greater than machine 3 because it is not connected to the transor system.
If you have any additional questions i can try to provide them.
28-32m/sec came from our parent company. They are european and design and modify alot of their machines for our business. Yes, i agree it will be alot of fluid spraying at the grinding site.
