Gymnast
- Mar 22, 2008
- 22
I am trying to improve an air pump to an gymnastics airtrack regarding the pressure drop in the pipes. In general the system consists of a vacuum cleaner motor, some 2" pipes, valve, T's and flexible 2" PVC hoses with Camlock connectors.
I have tried to calculate the pressure loss using these two tools:
However I get some problems in estimating the equivalent piping material for the hose. The hose is like this seen here:
Can I expect the manufacturer to give me information regarding surface roughness for flow calculation? What is your estimate?
Furthermore the Camlock connectors for the hose locally reduce the pipe size to about 1.6 inch in diameter and the connector itself is not ideal. Can I in some way estimate the pressure loss from such connectors? Or do someone already hold the right friction factors for such connectors?
Thank you in advance for your help.
