I have the following situtation regarding the installation of a water pressure tank and I would like some advice:
I have a well with a submersible pump, pumping water to two 1000 gls storage tanks adjacent to the well site. About 1100 feet away from here there is going to be a shed with a pressure tank to supply water to a few surrounding facilities. I am a little confused about what to do to feed this pressure tank. I could install a pump besides the storage tanks but the problem is it is quite far to send the signal from the pressure switch at the pressure tank to the pump at the well site. Then again I could put the pressure switch at the pump outlet at the well site, with the pressure setting for the pressure tank plus the friction losses in the 1100 ft pipe. I am not sure however is that is going to work allright. Any suggestions or comments are most welcome.
Thank you,
Thank you,
