tactical14
- Feb 13, 2012
- 15
If I mount the following object on a V block at point A and put a indicator at point B, what am I measuring? Basically I want to see if the two diameter's center lines are collinear.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
pmarc said:Let's say that I have a will, time and money to try to inspect ASME's Concentricity of an external cylinder relative to datum axis derived from other external cylinder with the use of single dial indicator and a chuck...
