Toronto place crash 4
LittleInch
Petroleum
Mar 27, 2013
22,499
A Delta plane appears to have touched a wing tip during landing, ripped the wing off then promptly flipped over onto its back.
As they were on the airfield and this time didn't run into anything or catch fire, everyone is alive, though not surprisingly some injuries.
This video https://www.dailymail.co.uk/news/article-14407855/delta-plane-crash-toronto-fireball-footage.html makes it look like a very hard landing - no visible flare
I want to have a look at the top arm pivot point and yoke on the main gear.
Will see if I can find one on the apron tomorrow and get sone pictures.
Don't know anyone that fly's one.
I haven't seen that one. That videos shows the severity of the impact much better. I think this video helps rule out wind gusts as a factor. Nothing changes about the airplane's flight path. It doesn't bank, it doesn't yaw, it doesn't sink, it doesn't flare, it just flies straight into the ground.
I used to worry about safety going to and from flyin camps.
Fly in, work for 14 days, fly out, 7 days off and fly in.
And of course ther were overlaps.
The plane that I flew in on would take a full load of workers back out.
There were a lot of flights. (Several thousand men in camp. One project had a 7500 man camp and a short distance away, a 5000 man camp.)
I have seen as many as three 737s on the apron at once on flyin day.
This was (IATA: HZP, ICAO: CYNR)
This was a privately owned airstrip adjacent to the camps, for the use of the Oil Company.
I imagine that there was a lot of pressure on the charter operators to be on time.
One flight was a little late.
The pilot opted to land with the wind rather than take the time to go downwind and come back.
There must have been a wind gust.
The plane dropped suddenly onto the runway.
A couple of overhead compartments flew open and quite a few oxygen masks deployed.
There were a couple of sore backs.
I had to suspect that some aircraft defects may have gone unreported until the contracted flights were done for the day.
But Big Oil was paying the bills, and in Alberta Big Oil rules.
Fly on time, regardless or we get someone else.
Pivot point and how landing gear mounts to wing spar? I am thinking it is just as likely than wing mounting point for landing gear pivot point could have failed.
The other thing is the diagonal arm that locks landing gear in down position and the mounting point to gear and structure. In my viewing of the poor resolution videos, I can't tell whether wheel goes straight up or swings up, or some of both as it vanishes.
It may have swung up
Can you please offer your interpretation of this picture? I see some white stuff and some less white stuff.
This is what I have managed to find.
Wouldn't suprise me if the c-series is very similar.which is going to be my first port of call when I go to work today.
That's a picture of the right wing which detached. It's interesting in that the main gear is still attached to the wing, but has folded back up into it's retracted position showing a possible failure of the locking mechanism which made the gear essentially fold back up under the plane. As can be seen from the front view, if you lose a landing gear the wing will impact the ground as there is no engine to slide down the tarmac.
If the gear is still attached to the main spar then the spar box has failed or the spar to box connection.
That's not unheard of, corrosion and maintenance events can be a factor.
Here's another image of the detached wing and gear showing the gear most likely is in the retracted position. At first I thought it punched straight on up like other failures have but seems not.
Question for the pilots here. Please correct me if I am wrong.
At the time of their rapid rate of descent, their ground speed via ADS-B was 110kt. Assuming the plane was coming in light, at flaps 45, VREF should be no less than 121kt and 131kt minimum maneuvering speed. Obviously the heavier the plane is, the more those minimums increase. With wind from 270* of 25kt, gusting up, they should have been experiencing ~16kt crosswind and around 126-136KIAS. If ground level shear was enough that day to have had a pocket of calm air and your crosswind dropped to 0 50ft above the ground as you cross the shearline, what likely would be the outcome? Videos of fire crews working on the crash, some videos from passengers exiting the plane, and the fire chief's odd statements of the weather seem it would indicate that as the scene of the crash landing, weather was calmer with only the occasional heavy gust versus the strong sustained winds the pilots were dealing with on the way in. Guestimating off of nearby utility poles, most, if not all of the maintenance hangers and fire hall from the direction of the wind are in the 45-60ft tall range. Roughly 2500ft from the firehall to where the CRJ contacted the runway. Had they suddenly lost that crosswind, they'd be closer to their stall speed than landing speed and I'm sure they'd have had no energy to flare.
There were go-arounds before their attempted landing due to shear. Severity of which hasn't been stated by officials yet as far as I am aware.
The slight increase in ROD very close to landing with the dip of the right wing, somewhat looks like the beginning of a low level stall, or incorrect control inputs due to a change of wind.
Perhaps Pilots can resppond:
A consistent theme online is that CRJ's have a narrow sweet spot between floating and stalling on landings. Some types being more sensitive than others, and flare pitch and Vref varies on type. I read the CRJ900 needs less flare. Edit for typo: "Too much flare and it descends hard and at an angle to landing struts suspension axis, too much velocity and you float down the runway.
Also I read about stall induced rolll, which adds additional forces to right side landing gear it appears. Due to angle this force changes the ratio of horizontal force to vertical force. Thus applying lots more lateral load on locking diagonal actuator arm. Landing on one side first, potentially doubles hard landing load on right side landing gear, and if only on one of two tires initially receives majority of load, then horizontal force vector increases again.
And all this force is resisted by what appears to be a small pin connection at pivot point on landing strut, relative to the size of the bolt with nut holding the diagonal actuator arm interface termination to the actuator arm housing.
Will add arrows to image above.
Yes thanks, I edited typo above.
I wonder if the stainless lines in Ali's pictures are fuel lines, that could have been damaged when landing gear collapsed hard into wing?
Cs has got electric brakes. No fuel or hydraulic lines on the gear. IMG_20250223_111354855_HDR_AE.jpg
That's fuel tank wall on the left
This is a A220 cs300 wheel bay
I did try and find a crj today but we didn't park near one.
