I've been asked to look at a residential truss repair. The truss spans about 20 ft. The contractor has replaced the damaged members of the truss and is proposing using 12"x12" OSB gusset plates where the members connect. At one connection where the web connects to the bottom chord, the bottom chord has been spliced. See the attached jpeg. Right now there is only a Simpson tie plate holding the chord together.
I don't like the splice being under the web members (at the joint), but at this point I don't think moving it is an option. My thought was to replace the tie plate with a couple of Simpson straps - e.g. an MSTC along the side (where the tie plate currently is), and maybe an MSTA strap along the bottom edge. And then tie the whole joint together with the OSB gusset.
I haven't calculated the loads yet, but I would appreciate anyone's initial thoughts or opinions about how I'm thinking on tying this together.
Thanks!
Thanks!
