Delmarva_Struct
- Aug 23, 2022
- 31
For an enclosed building, the wind uplift force on a roof is caused by difference of pressures above and below the roof membrane. The motion of the wind blowing over the roof creates a area of low pressure and the air under the roof membrane is at a higher pressure and so the wind tries to move from below the roof membrane to above the roof membrane and this creates the uplift force.
Now my question is related to cold storage facilities. Considering that these facilities are constantly keep below freezing. The pressure within the building will be very low. I don't see how this pressure can be higher the pressure over the roof to cause an uplift force.
In this case, can I ignore uplift forces on roof membrane for cold storage facilities?
