GregLocock
Automotive
- Apr 10, 2001
- 23,540
A dispute over how the Bureau of Meteorology records daily temperatures is hotting up, with the release of more than 1000 pages of data that show new probes can record different temperatures to mercury thermometers in the same location at the same time.
The documents, released after a years-long Freedom of Information campaign, show temperature measurements taken using updated BOM probes in automatic weather stations at the Brisbane Airport site could be up to 0.7C warmer than the temperature taken using a traditional thermometer at the same time at the same site.
More than three years after a FOI request for parallel data was lodged by scientist John Abbot, the BOM released three years of data on Easter eve after the matter was taken to the Administrative Appeals Tribunal.
In the end, the BOM released only limited data, paving the way for a wave of FOI demands that full records be released in the public interest.
Release of the data is the first opportunity to analyse the performance of BOM probes alongside mercury thermometers. The bureau has long claimed the readings are identical but critics have said the BOM was not following World Meteorological Organisation guidelines on how they should be used.
0.7 degrees eh? So if that's consistent, about half the warming BoM reported since 1900 is due to change of instrumentation. Oops.
Cheers
Greg Locock
Cheers
Greg Locock
