dik
- Apr 13, 2001
- 26,064
One of these times, something serious could happen.
![[bomb] [bomb] [bomb]](/data/assets/smilies/bomb.gif)
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I love your understated sarcasm, dik.Dik said:One of these times, something serious could happen.
LittleInch said:a set of C shaped clips to go over say 4 of the stop pads which could then be fixed to the door using cables so they don't get lost if the door is removed at any point.
waross said:No, The springs are compressed when the door is closed.
In normal closed position the springs are compressed and pushing upwards.
Thanks. That's a whole 'nother story. I thought it was in reference to the stop bolts that held the door in position to keep it from moving up. Now I've seen pictures of the closure hardware bolts hanging out. A much bigger issue, to be sure. Now I see why the FAA has kept the planes on the ground. Nobody is even sure what to check for yet.3DDave said:The loose bolts are on neighboring fittings...
