Tomfh
- Feb 27, 2005
- 3,584
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
This thruster most likely needs two of the service generators on line to reliably start. It could not be operated from the emergency bus or from one generator due to not enough generating capacity. The bow thruster is interesting, but not in play for this event (my opinion). I was not able to find anything referencing the Dali's emergency generator size.[URL unfurl="true" said:https://en.wikipedia.org/wiki/MV_Dali[/URL]]For maneuvering in ports, Dali has a single 3,000 kW (4,000 hp) bow thruster. Electricity is generated onboard by two 3,840 kW (5,150 hp) and two 4,400 kW (5,900 hp) auxiliary diesel generator
Momentum is a vector quantity M = m * V , caps imply vector, and m = hugestevenal said:.. thrusters' ability to re-direct momentum ..
RoopinderTara said:Here's a call for action on bridge protection, mainly bigger dolphins ...
I'm concerned that the dolphins can stop the ship but then tear into the hull in a way the overhanging portion still reaches the bridge pillars.
3DDave said:MV Dali had the hull torn open and did not sink because of it; sinking is not a problem that needs addressing. Refloating a ship that is a few feet lower in the water than normal isn't a huge problem ...
