Saedhalteh
- Nov 8, 2019
- 43
Hello all
I learning RAM concept and I am new to the field and I hope you can help me with my question.
There is an option to Consider Axial Force in Strength Design and I have read in the manual that this option means :
(using the net section axial force in bending design.
This is a very important setting related to the effect of axial force resultants (not necessarily axial loads) in a crosssection. If you select this option, RAM Concept includes the interaction of the axial force with the bending in the cross section strain calculations, similar to typicalcolumn design using strain compatibility)
my question is it recommended to use this option or it is better to ignore it ? and why ?
