JAE
- Jun 27, 2000
- 15,577
So in 1995 Denver, Colorado, built a large airport. The main floor was designed for 250 psf live load - equivalent to that required for heavy storage loads and provided for equipment necessary to erect the large 150 ft. span "mountain" tent roof.
They now are in the midst of a large renovation project ($1.8 billion I think) and recently they hit a snag in that some concrete cores on the floor came up lower than the original 1995 specified concrete compressive strength.
I searched for information on the numbers here but didn't find anything.
I am a little suspicious of the lower strengths in that concrete coring doesn't always reflect the full strength of the concrete...i.e. ACI even allows you to compare your cores to 85% of the specified strength. I'm sure that the experts on board know that so the lower strengths may indeed be lower than 0.85f'c.
If there is lower strength then obviously this is a material supplier "failure" as opposed to an engineering failure. Hopefully the lower strengths aren't endemic to the whole structure.
faq731-376
faq731-376
