BAGW
- Jul 15, 2015
- 392
Is it necessary to keep all gusset plates the same thickness for all connection along length of the truss? Web member are double angles and top and bottom chord are wide flanges. Sometimes it becomes impossible to do this. If the gusset thickness varies over the truss length, how is the double angle welded to the connection. Say one end of the angle has 1/2" plate and the other end 1/4" plate, there is a difference of 1/4" between the two ends.
