Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I tend to agree... not with you sounding like a nut, but with the danger.HotRod10 said:know I may sound like a nut when I say this, but as I said before, an AI that sophisticated poses a greater danger to humanity than a few car wrecks.
VE1BLL said:If a system can handle a very busy street, then it should have enough processing power that it can pay attention to a single pedestrian on an otherwise deserted street.
VE1BLL said:It'd be a design flaw if it was overzealous in ignoring the one and only moving object about to intersect, given that it should have had not much else to do.
Velocity: 27.8 m/s
Stopping distance: 78.7 m
FOV across: 698e-3 rad
FOV up: 175e-3 rad
Laser pulse rate: 1.00e6 Hz
LiDAR scan rate: 10.0 Hz
LiDAR FOV: 2.21e-3 rad
LiDAR scan: 632x158 = 99856
LiDAR spot size: 174e-3 m
Sanity Check: Laser TOF should be shorter than laser period.
Time of flight: 524e-9 s
Laser Period: 1.00e-6 s
Factor: 1.91 Okay.
lionelhutz said:You're free to conclude whatever silly explanation you want
LionelHutz said:As you've pointed out already, the sensor data will always returns data from the objects in front of the car
IRStuff said:The bike isn't relevant; the pedestrian, by herself, should have presented a more than valid and substantive target. The lidar is specified to have at least 60-m range against pavement with 20% reflectivity. A person, wearing black clothing, should be very visible at 60 ft; the lidar should be able to see reflected signal from a 2% reflective surface.
