drawoh
- Oct 1, 2002
- 8,954
This thread is continued from thread815-437388.
JHG
JHG
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
HotRod10 said:Per the traffic laws, you are not supposed to pull out into the intersection until it is clear to make the turn.
NTSB Report said:At 1.3 seconds before impact, the self-driving system determined that emergency braking was needed to mitigate a collision. According to Uber emergency braking maneuvers are not enabled while the vehicle is under computer control to reduce the potential for erratic vehicle behavior. The vehicle operator is relied on to intervene and take action. The system is not designed to alert the operator.
NTSB report said:The vehicle operator said in an NTSB interview that she had been monitoring the self-driving interface and that while her personal and business phones were in the vehicle neither were in use until after the crash.
IRstuff said:OK, at least, the sensing system performed exactly designed, including detecting the pedestrian at over 500-ft distance, as expected.
IRstuff said:The rest is a complete fubar; it basically allowed nearly 5 seconds to lapse before figuring out that it couldn't brake and needed to warn the driver. No wonder Uber is shutting down that operation; the people that came up with that logic should never be allowed to work on anything safety related again. This is one of the few times I think licensing such engineers ought to be a requirement.
JHG said:Uber's decision....the driver was in control, and that she should have been watching forward, gripping the wheel...
NTSB Preliminary Report said:The operator can transition from computer control to manual control by providing input to the steering wheel, brake pedal, accelerator pedal, a disengage button, or a disable button.
GregLocock said:At 1.3 seconds before impact, the self-driving system determined that an emergency braking maneuver was needed to mitigate a collision...
....I get 43mph for six seconds as 115m, or 380ft. If a LiDAR could scan ahead 115m and identify you as LionelHutz, poster on Eng-Tips.com, and work out whether to run you over or not, it would be remarkable. Any object identified by a robot must not be run into. The space the object occupies must not be passed through. The robot must avoid the object by some minimum distance because it may do something unpredictable, and there may be something behind the object that is moving.....
I have just crunched this number. At 43mph, a panic stop at 0.9G (achievable?) takes 2.2s, and 21m (69ft) of road. There is nothing the human could have done even with infinitesimal reaction and evaluation time.
For intersections with lights, the car should already have the capability to decipher the lights and make valid decisions.
