Style question with ordinate dims, datum surfaces
patdh1028
39
Hi All,
I just started a new job and got handed back a checked drawing with Red Ink all over it. The points at-issue:
1. Ordinate "Zero" aligned with datum surfaces. I don't operate under a rule where zero must be at a datum surface. Sometimes it is, sometimes not. My philosophy is that I dimension the part to be concise and clear on the drawing document, then I tolerance the part (with GD&T) to represent the functional/design requirements of an acceptable production. Red ink on my drawing re-sets my datum references to be all planar exterior surfaces and sets all my ordinate zeros to these surfaces. This is hard to explain with words and I can't post the drawing itself obviously, but my original datums were: A: A mating surface that interfaces with another part's surface via bolted connection, B: A dowel hole on A, C: a second hole with a tight diameter tol on A. The red ink keeps A as-is, sets B to one side of the part exterior normal to A, sets C to another side of the part normal to A and B, and adds a datum D which is the dowel hole. I acknowledge that this is totally acceptable to do, but here's why that layout bothers me: Too many controlled surfaces, and one otherwise unnecessary re-fixturing at inspection (with datum D). Simple fact is that I don't care if the dowel hole is tightly located to the side exterior surface of the part - I care that it is located versus other holes in the part. The outside profile can be comparatively sloppy and function perfectly adequately in the design, hence my original spec.
2. Dimension QTY on center-marked AND connection-lined hole pattern. I've always just kind of assumed that if you have hole center-marks that are connected to each other, I put the dim to one center-mark with no QTY and the connection line implies that dim carries to all holes on the connection line - I've seen this in the Standard and for years at my previous employer. The Red Ink says to put the QTY of holes on that dim, i.e. "4X 7.0mm" but that strikes me as redundant to the purpose of the connection lines. I would say if there are no connection lines, absolutely add QTY. Also if there are different entity types, like an edge that aligns to the connection line or center mark, definitely add a QTY. But requiring QTY AND connection lines simultaneously bug me.
The justification for the "purely external and planar" datum reference, as explained to me briefly by the originator of the Red Ink, isn't necessarily a bad one where you're supposed to be making it easy for the machinist to identify critical dims, and ostensibly this part would have its exterior profile cut prior to the holes... Also of course the inspection setup is easier initially for ABC, but requires two setups because other hole location tols are to ADB because the dowel hole is now D. My counter-argument is that by making the datum references from explicitly-functional geometry, I am more clearly conveying the design intent to the machinist, identifying one surface and two holes as critical and tolerancing non-critical geometry like exterior profile as such. Personally I think I understand the implementation of GD&T better than Red Ink, who reset my reference frame but also leaves Datums B and C controlled only by limits of size - in my understanding, this actually makes it more difficult for the machinist to produce a part that will pass inspection because even if he can hit the tight tolerances from the exterior surface datums as the part is fixtured in the machine, once that part is fixtured to the datum reference according to the location tolerance callouts it will almost certainly fail unless the machinist understood implicitly that those exterior surfaces will have to be very nearly orthogonal for the tight location to be valid on the inspection table.
Sorry for the long post, but am I way off here? Regardless of what's posted back here, I'm not going and telling the senior engineer that my way is better... but for my own personal development, being self-taught GD&T and having almost zero direct fabrication/machining experience, which philosophy is better?
As for the ordinate 0, the coordinate system of the part just needs to be related to the datum reference frame...it doesn't have to be identical to it.
I think you each have a point. On issue number one. Why is there ordinate dimensioning at all? Just get rid of it. Basic dimensions should tie all your features back to datums anyway. Who cares where the zero is? To your point though, dimensioning off of planar edges as if it somehow helps the machinist is a misguided effort at being helpful. Your way is the better way in this case. On issue number two I'll have to side with the devil with the red pen. What is a connection line? Is that a real term or are you calling it what you want it to do? What happens when holes are in the same line but the inner ones are a different size than the outer ones? He's right on this one.
In my opinion, you're not far off and neither is he.
John Acosta, GDTP S-0731
Engineering Technician
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
I worked at a place that did the same, it was really dimensioning for manufacturing. The large surfaces are machined first and then used to set up all other operations. IMHO, It is not the intent per the standard but is a result of blind adherence to old style manufacturing practices. The biggest issue I have with it is the rules say locations for GEO tolerances must be defined basic to the datums that are referenced in the FCF. This basic chain often falls apart with this style is mixed with plus/minus dimensions and, in that sense, becomes an actual violation of the law of the standard.
Frank
Dimensioning and tolerancing for manufacturing rather than for function is risky. If a drawing is created for Supplier A with their own setup and process, what happens when the design is sourced from Supplier B with a different manufacturing setup or process?
Drawings (specifications) should be supplier agnostic to avoid this issue. If dimensioned and toleranced for function, the Supplier A versus Supplier B issue is avoided altogether.
The first one seems like... personal preference, honestly, even if your drawings /are/ being manufactured from.
Just because holes line up on perfect centers or orientations does not mean they're the same diameter. Indicating the quantity of 7.0mm holes clears that up. Centerlines only indicate a location or pattern. They do not indicate that holes are identical.
_________________________________________
NX8.0, Solidworks 2014, AutoCAD, Enovia V5
Is there a possible compromise?
Ordinate dimensions can be made Basic.
Because Basic dimensions do not introduce tolerance accumulation, the "zero" point can be made anywhere, including where Manufacturing will like it.
The datums nevertheless can be assigned the way that represents function (as Engineering understands it)
 http://files.engineering.com/getfile.aspx?folder=abaa7393-dab8-4cb5-aa8f-d1a6d528a801&file=Draw1.JPG
CH,
Of course, I believe it can be done or is allowable. Airplane manufacturers and Car companies often used universal origins.
Frank
How about changing to model based definitions?
In MBD, there are no explicit dimensions other than size tolerances. If one wants to interrogate the CAD model, one can get what the basic dimensions would have been.
Auto OEMs are going this route. Most don't even put basics on drawings...with the exception of the powertrain and suspension groups.
Oh, that works fine.
Model is basic, you may put your GD&T on drawing to have something reviewed and signed on the paper.
Unfortunately OP's problem is more of company policy / personal preference problem.
"We always did it that way" AKA "5 monkeys experiment"
Thanks for your input everyone. To clarify the connection-line hole pattern, there are many figures in Y14.5-2009 that dimension to multiple holes oriented on a line and drawn with connection lines between center marks. I put hole QTY in the size callout for the hole, and do not place it on the location dimension(s). If you have hole centers oriented vertically, for example, regardless of size, and there are centerlines connecting the center marks of the holes (what I was calling "connection lines"), it's my opinion that putting a QTY in the locating dimensions to indicate the number of hole centers is redundant. If there were just center marks without the connecting center lines, I would agree that QTY in the locating dimension is required. The Standard doesn't clarify as far as I've been able to find, but it is in numerous figures. See figs. 7-38, 7-52, 4-8, 4-7, etc - I haven't yet found any figure that lists a hole-center QTY on a location dim.
Model-based is what I'd prefer - actually I asked before I drew the part if I could put only tols on the drawing and send a 3D file for the basic dims. For complex geometry I think trying to dim and tol it just makes the drawing cluttered and confusing. I was told people are still manually programming the machine tools at the shops we use so the drawing should have all required dims and tols. I mean, I'll draw anything but that doesn't necessarily mean it's going to be easier to program... At my last company even the smaller shops had sprung for MasterCAM or similar in the last two years. In New England with all the aerospace up here I think that has been driving it.
In time I think (hope) there will be less oversight on my drawings and I can pretty much do it the way I think is best. Since I just started at this company all my drawings are up for thorough review and are being "corrected" extensively based on personal style and preference rather than adherence to the standard or actual correctness. So for now I'm just implementing someone else's preference and not putting up much of a fight.
IMHO ordinate dimensioning should only be used when you need to save space on the drawing because it tends to "wash out" the functionality of the feature patterns. Granted, hole call outs and hole designators can maintain that functionality, it is unnecessarily subtle. If someone wants to confirm (at a glance and without calculation) that a component mates with a hole pattern then the hole pattern should be dimensioned functionally between holes. Of course a mix between the two, where the leading hole is located with an ordinate dimension and the in-pattern holes are dimensioned directly is probably an optimum way to do it.
Tunalover
patdh1028,
I've seen this issue (#2) crop up here as well. My personal opinion is (that and $5 will get you coffee at Starbucks) that if there's only one way the drawing can be interpreted and it doesn't violate standards, it's good. So, if you have holes connected by center lines, to me it's completely clear that the same dimension applies to both and 2X would be redundant (but not necessarily wrong).
