Truss connector plates
mjr6550
69
I am trying to determine the manufacturer of truss connector plates used in dimensional lumber roof trusses built in 1994. The only marking on the plates is 8D-4. The plates are a relatively common design, but the designation does not match any plates I am familiar with. I have contacted one manufacturer and the Truss Plate Institute so far, and they were unable to identify the plates. Anyone recognize that designation?
I should mention that one reason I am looking for information regarding these plates is that many of the plates have partially withdrawn from the wood. Some plates are cupped and some have even fully withdrawn. I have seen partially withdrawn plates many times, but never this many or this much average withdraw. One thought was defective plates, but I have seen dozens of houses in the same development and other developments built by the same builder and this is not a common condition. My thinking as of now is that it is moisture related. There was evidence of excessive moisture accumulation in the attic (stained and discolored roof sheathing).
What are you going to do with that information? Might as well just add some gussets and be done with it. I have seen plates withdraw do the significant changes in wood moisture content. The shrinking and swelling supposedly can make the plates back out.
I was looking for the information for two reasons. I was curious as to whether there was some problem with these plates, which I did not really think was likely. The other reason was to obtain design data for the plates. This project has about 5 different truss designs and several are complicated designs. Measuring the trusses to come up with forces would take quite a bit of time. When I have plate details I usually determine the plate area at each member/joint and design the gussets to exceed the design values for the plates.
BTW, I did find out that the plates were made by Alpine. I contacted them and have not received a response yet.
You should be able to ballpark the forces in the members pretty easily.
I think truss plates have about an 80 psi capacity. Let me know what you find out.
