I need some help with a part that consists of 2 V grooves which I want to determine as datums.
Both 36 diameter pins should be the primary datum. The dowel holes must be perpendicular to the plane that connects the pin's center lines.
I am not sure on how to even start.
Any assist will be much appriciated.
Thank you,
Alex.
Thank you,
Alex.
