Ok, I dropped that in because I think it's a good idea than can save lives and reduce the impact of smoke inhalation. Repeat "can". It's not a solution to everything by any means, but the information from the fire in London is that there are currently 17 people still in critical condition suffering from smoke inhalation, but the burns unit set up by the hospitals didn't treat anyone. Sure, if the stairwell is full of smoke to the extent that even crawling along the floor you can't see, you're in great danger, but doing it still being able to breathe and not coughing / unable to breathe must be better than not. If you make it to the stairwell then it is a concrete shell hopefully protected by fire doors, but clearly often fills with smoke.
This discussion is going the same way as the argument over bike helmets (push bikes) goes sometimes - Do they protect you in all incidents / major crashes - NO. Do they protect you from minor crashes / falls which otherwise can be life threatening - Yes.
Fires in buildings like this normally take several minutes / hours to fully take hold. That's more than enough time to find your protective devices, especially if you've fitted them next to the door.
Would I rather give my self a decent chance of survival compared to not doing so - yes I would. Would it make a difference in a very fierce fire, probably not, but if 50% or 40% or 30% more people survived or equally survived without life changing injuries caused by smoke inhalation and these devices cost £25 each I think it's a wise investment. My personal view.
Fire protection in many high rise buildings is based on containing the fire allowing time either for extinguishing or an orderly evacuation. Retrofitting sprinklers and hardening the escape routes is going to be expensive and time consuming. All I'm saying is maybe we should also be looking at providing greater protection for those who stay put or need to evacuate to stop people jumping out of windows or throwing children out because they can't breathe.
The argument has been made in aircraft evacuations where there is a much greater issue over the speed of evacuation versus time to find and put on said equipment. Fires in buildings are normally much slower to develop so that argument doesn't hold IMO. If your room is so smoke filled that you can't see anything then you've pretty much had it, but that's an extreme event that takes time to develop unless the fire is in your room, when it's time to get out.
One thing I would like to know is what the design of the windows was with this refurb. I saw a clip on the news yesterday of a different block and it looked like the window ledge and window frame had been extended out along with the insulation, but this meant that any fire inside the insulation would propogate into the building much faster than if the fire was outside the window frame. I haven't seen any close details yet - anyone seen them?
