- Moderator
- #341
It's only recently that they stopped putting the retaining bolts in place.Those spare doors have been around for a long time since the 737-900 I think so many hours of service and they haven't fallen off before...
Sensors and pressure:
I surmise that it wasn't a failure as much as slightly slower pressure build-up due to an unseated door.
One sensor may have been slightly differently calibrated or differently placed.
Example:
A burner in an oil heater had a tendency to build up soot on the fire eye.
Eventually, the soot build-up would prevent a successful start.
Solution;
The fire eye had 7 seconds to see the flame else it aborted the start.
We programmed an alarm at 3 seconds.The alarm simply latched a pilot light that indicated;
"Slow Light-Off."
When the "Slow Light-Off" light came on the tech's could clean the fire eye at their convenience.
The Max was probably showing slow pressure build-up rather than failure to build pressure.
Not a faulty sensor, but slightly different calibration of the sensors.
That's easy do diagnose in hind sight.
Much harder to find in the shop.
Ohm's law
Not just a good idea;
It's the LAW!
