Hangar under construction collapsed killing 3 and injuring more.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
29 U.S.C. § 654 said:Each employer shall furnish to each of his employees employment and a place of employment which are free from recognized hazards that are causing or are likely to cause death or serious physical harm to his employees."
29 U.S.C. § 654 said:Each employer shall comply with occupational safety and health standards promulgated under this act.
29 U.S.C. § 654 said:Each employee shall comply with occupational safety and health standards and all rules, regulations, and orders issued pursuant to this Act which are applicable to his own actions and conduct.
XR250 said:Is it possible that is simply not reasonable to assume that a structure of this size with such slender members cannot be erected with the current pool of labor?
I can see a situation where the EOR gets sued for just this very reason.
ChorasDen said:XR250, can you explain a bit more, I'm not sure I understand what you are saying here.
XR250 said:relying on "means and methods by others" may be considered negligent
WinelandV said:Too much of erection bracing comes down to how the building is erected
SwinnyGG said:Every time I've done big steel, the erection plan has been developed with significant participation from both the erector and the EOR
