Hi all,
In a plastics manufacturing extrusion tower,built of HSS,would a bolted connection designed in such a way that a 3/4" plate is welded to the section and then drilled and tapped through the plate and the HSS to accept an A-325 bolt be as acceptable as a bolted connection using a bolt and a nut.
Thanks for any help in advance.
