SeasonLee
- Sep 15, 2008
- 918
Attached print is a forged part around 11 inches long, there is a 3° draft angle all around the contour, for an irregular forged surfaces datum reference frame should be established by datum targets which could be points, lines or areas, the print note specified “all datum target areas are Ø.093”.(The original print specified with a X-shaped symbol as datum target area)
For datum A, it’s easy to understand a datum target areas A1, A2 and A3 could be assigned to on the flat surface, my questions are :
1. There is a 3° draft angle on the side wall datum B, shall we made a 3° end face on the B1 and B2 target pins ( Ø.093) to match with the side wall ? Why not to choose datum target points here ?
2. Besides 3° draft angle on Datum C, it’s a curved contour on this end, shall we made a 3° and curved end face on the C1 target pin ( Ø.093) to match with the part contour as well ? Can we use datum target points here ?
Any comment or help is appreciated
SeasonLee
