Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
JAE said:kazillion....let me get my slide rule out to check that...
winelandv said:Some 400 engineers trying to design something via forum? It would certainly be entertaining to watch.
On collapse, members #12 base was knock out by member #11 and pulled down from pylon together with member #11, by north deck fall.Stephen Nuchia (Electrical) said:... I note that the remaining portion of 12 seems to have a "chair" shape, the outside surface extends to somewhere above the location of the drain pipe while the spanward face ends higher, around deck level, and there seems to be a roughly rectilinear transition between the two cleavage planes. ...
LittleInch said:Hopefully some of the testimony of the survivors from the top of the deck doing the work will be able to shed some light.
Archie264 said:Hear, hear! All the minutiae about which member failed and how, while ultimately valuable, rather sidesteps the issue: this was a horrible design.
Ron said:This is exactly why an engineering firm should NEVER be a subconsultant to a contractor in design-build.
