Alistair_Heaton
- Nov 4, 2018
- 9,779
Just found this for solar fires in the UK.
Not many of them in the grand scale of things.
Interesting that isolators are the main culprit.
The Germans prefer to have a DC disconnect on the actual inverter. Hence I don't have them. There is no fusing in the UK to my knowledge on series strings. But I presume an inline locally install fuse box has the same risk as an isolator. I don't have either.
Connectors next on the list must admit I used sunclix because that's the make on kostal inverter. And the panels came with two mc4 connectors for every 10 panels one male and one female which where also sunclix (panels assembly done in Estonia by NAPs)
My inverter is mount on a concrete cellar wall.And there is a linked fire alarm down there. Many installations you see in solar groups they are in people's attics mounted on fibre board and battery sitting under them on wooden flooring.
But me doing that is more luck than judgement.
Wonder if some of these roof fires are linked to the old school firemen's isolators which are just a remote isolator.
