Things are Starting to Heat Up - Part V 6
dik
CA
thread1618-496010
thread1618-496614
thread1618-497017
thread1618-497239
You haven't convinced me...[hourglass]
With heat over time... the polar regions are warming at 4x the rest of the world.
Dik, I suggest you review your sources. They're getting worse and worse. Phys.org is anything but a non-profit. It's an arm of the ScienceX network feigning credibility with a .org domain.
GregLocock said:
OK, slowly. You have some very cold rock, and a mile high lump of ice on top of it. How does the heat in the atmosphere get to the ice/rock interface?
This mile-high lump of ice is surrounded on all fronts by seawater, which is changing temperature seasonally and also in the long term.
This mile high lump of ice weighs millions of tons and is constantly in motion on top of the pointy rock it's sitting on; in other words, it's generating a LOT of heat due to friction.
In short, the path to melting of the ice at the interface with the rock under it has nothing to do with heat conducting through the glacial cap.
There are areas of the antarctic continent which are known to have water between the base of the glacier and the underlying rock. This Stanford study looked at the possibility of basal melting in new areas; it did not invent the concept of basal melting itself.
I thought all glaciers had water underneath? It may not be heat related. It's hard for ice to form under pressure/weight. There is some unique property of water that makes this true.
NASA's climate division is again a questionable source. Without negative reporting it wouldn't exist.
Windows2Earth is a science teachers association. Science teachers typically aren't scientists.
Question your sources.
In one form or another... I seem to recall from grade school that it was called 'regelation' or something of that ilk. I guess the interlock with irregular soil surface tends to keep it anchored a bit... [pipe]
...and from Fox, too. Whoda guessed... Catch this link, it may be more pertinent. A sign of the times and of the frustration of scientists, perhaps.
Dik's article said:
Instead, they presented the case for scientists to adopt a more radical approach to counter the "lack of transformational government action":
You're proving my point. This is no longer about climate or science. It's strictly political now.
