Maybe people have to cut back on their use of power? I don't think there is an easy solution.
Solar cells are a work in progress, albeit maybe not fast enough.
"The findings appear in the journal Matter, in a paper by MIT research scientist Shijing Sun, MIT professors, Moungi Bawendi, John Fisher, and Tonio Buonassisi, who is also a principal investigator at the Singapore-MIT Alliance for Research and Technology (SMART), and 16 others from MIT, Germany, Singapore, Colorado, and New York.
Perovskites are a broad class of materials characterized by the way atoms are arranged in their layered crystal lattice. These layers, described by convention as A, B, and X, can each consist of a variety of different atoms or compounds. So, searching through the entire universe of such combinations to find the best candidates to meet specific goals — longevity, efficiency, manufacturability, and availability of source materials — is a slow and painstaking process, and largely one without any map for guidance.
“If you consider even just three elements, the most common ones in perovskites that people sub in and out are on the A site of the perovskite crystal structure,” which can each easily be varied by 1-percent increments in their relative composition, Buonassisi says. “The number of steps becomes just preposterous. It becomes very, very large” and thus impractical to search through systematically. Each step involves the complex synthesis process of creating a new material and then testing its degradation, which even under accelerated aging conditions is a time-consuming process."
