Things are Starting to Warm Up Part III 6
dik
25,675
For earlier thread, see
thread1618-496010: Things are Starting to Warm Up.
thread1618-496614: Things are Starting to Warm Up Part II
That's a real big part of the problem... I wouldn't trust most of those piloting the Ships (of State) to look after my kids. They are not up to simple tasks, let alone difficult ones.
Dik, it's a problem of creating rules with no clear path to compliance. The rules will adversely impact 75% of the world's cargo fleet. And we thought the pandemic related shortages were bad. Starting in 168 days, expect things to get much worse.
I suspect that not only shipping will be affected... I hope that people aren't the new lemmings. Another concern I have is that those in power may panic and scramble, and do something really silly (with apologies to Monty Python). We are likely heading into totally new territory. [pipe]
Back to tall sailing ships. May put you out of a job, Tug. Never heard of a tugboat relying on wind. But I suppose that makes about as much sense as base load power for cities relying on wind, or the sun for that matter.
Yes but up here in the (decreasingly) Frozen North they are making danm sure you get your pronouns correct. The logical extremes resulting from illogical extremists dictating language norms is fines and jail terms. But I digress.
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
brims... scary, eh? [ponder]
Indeed; I am not exagerrating when I tell you I can be fired in a minute for a single 'incorrect thought' expressed on the in email. All quite risky when you figure out that social media is basically a mind reading technology.
It's all become a bit Cultural Revolutiony and fundamentalist.
It all makes sense now.
Logic's not your strong suit is it Tug?
brims... Quit it!
Sorry dik,
Faulty and false logic informs most of the Denialist’s objections, and it has to be called out.
I can’t do the work of separating the BS from the cherry picked facts; only the Deniers can do that.
Can we return to the topic of the forum ... Engineering solutions ...
Let us assume ...
1) Climate change is driven by humankind's CO2 emissions.
2) Continuing to produce CO2 emissions is an existential threat to human civilisation.
One and only one rule ... no reply "but it's fact, don't assume".
With this as a problem statement, can we propose solutions.
maybe ...
1) In order to combat climate change, I propose to reduce CO2 emissions by ...
2) In order to mitigate the effects of climate change, I propose to protect against sealevel rise by ...
Including the issues the engineering solution will have to address... sure... [pipe]
This whole thread, both parts, exists to post a link to every single weather related event that happens and blame it solely on climate change.
It's a method of censorship. Drown out any meaningful comments with noise.
Hokie66 says he "never heard of a tugboat relying on wind."
"The late Capt. Lane Briggs ' Tugatine is a favorite flagship for sail-assisted working vessels and is credited with a 1984 circumnavigation of Virginia...It's the world's only purpose-built sailing tugboat and uses its sails to save fuel."
The article didn't mention that Capt. Briggs was the founder of SAILA in the 1970s, to promote sail-assisted workboats. I have their brochure somewhere.
I concede. But am still trying to figure out how you can circumnavigate Virginia.
Not blaming it, it's a consequence of climate change, and likely going to get worse... [pipe]
