thebard3
Chemical
- May 4, 2018
- 746
An interesting theory from the article: "Italian news agency ANSA said authorities suspected that a structural weakness caused the collapse".
Brad Waybright
It's all okay as long as it's okay.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Well, you have to define 'faulty', and what the reason for it might be. In this case, the bridge was unique, and probably required additional and unconventional maintenance, but it DID stand for over 50 years. The design was probably less than ideal, but continuous improvement requires new designs and technologies that don't always show their shortcomings until years or decades later. Like hokie66 pointed out--cranky108 said:On the other hand, what should happen to an engineer that designs a faulty structure?
Just because the Pantheon has stood for 2000 years doesn't mean it's an ideal structure. If something is truly deemed 'faulty' because it used questionable materials, designs, techniques and the like, then there should probably be some culpability. If it seemed like a good design at the time and failed due to unforeseen circumstance, then not so much. That question probably gets addressed as part of the FIU bridge collapse.hokie66 said:Your definition of "overbuilt" differs from mine. That big concrete dome is completely unreinforced. That would be considered inadequate today.
Popular Mechanics said:Reports range from 27 to 180 deaths as a result of rear-impact-related fuel tank fires in the Pinto, but given the volume of more than 2.2 million vehicles sold, the death rate was not substantially different from that of vehicles by Ford's competitors. The far more damaging result for Ford was the PR disaster.
thebard3 said:Maybe someone should start a Pinto thread. I'd tell stories about my sister's Vega.
EmmanuelTop said:Root cause analysis should identify one, and one cause only, why the structure failed.
The Pinto was rear-wheel drive. It was constructed on the large car model shrunk down: body bolted on a weighty frame. Very heavy.waross said:Also, the Pinto being a light front wheel drive vehicle, a car striking from the rear could more easily lift the rear of the Pinto and contact the gas tank.
