Things are Starting to Heat Up - Part V 6
dik
CA
thread1618-496010
thread1618-496614
thread1618-497017
thread1618-497239
Can you point out the faulty information? [ponder]
The information you share isn't faulty, it's groomed in order to make you act out of emotion instead of reason. You say it yourself. Something must be done because we don't know what will happen.
Sorry Tug, none of my comments are emotional... I'm cool as a cucumber all the time. I'm just an observer at this point.
This problem should have been addressed 20 years back or more, rather than just paying 'lip service' to it. There still hasn't been a concerted effort to address it, and it may be well beyond the point where we can make a difference. I do notice that climate events are getting worse, and more frequent than in relatively recent past, and I suspect things can get a lot worse. I don't want to sit down and put together a list of possible/probable 'uglies' that could result. [pipe]
When you say that you notice climate events are getting more severe and more frequent, I can't believe that to be true. I doubt you've experienced worsening severe weather in your own climate. I think what you have noticed is an increase in reporting on severe weather events around the world.
Another article about a normal weather event. At least they didn't blame the event in climate change. Merely that we should prepare for weather like it. Isn't that how we always used to prepare? We'd build for the "100 year event".
Even the inventor of carbon capture came out recently and said it was a waste of resources. More snake oil. Let it fail, we need to stop wasting money on these stupid projects.
Even with viable solutions... there will be a variation in outcomes... some good, some not so good. Remember, we are in new territory. [pipe]
Then let's stop funneling money into the pockets of venture capitalists and invest in improving our existing infrastructure with today's technology.
It's crazy to support projects like this when they can't even stand up to high school level scrutiny. Whatever makes you feel warm and fuzzy inside I guess.
And when you are primed for it, you start noticing weather events a lot more. You have in your mind climate change, and so climate change is what you see. It’s rampant in Australia. Statistically normal flooding being pointed to as clear an undeniable signs of the climate apocalypse.
It’s similar to when you work on a certain problem, or renovate your house a certain way with a certain finish, and you start seeing examples everywhere.
I have no experience researching psychology papers, however its interesting to note that searching for papers related to psychology and climate change results in a flood that all seem to assume negative climate change to be fact, not theory. It almost seems anti-science.
Dik, did you miss my high school analysis of why bobbing buoys won't work? Why do you keep peddling snake oil? Do you get paid to post this junk?
