Things are Starting to Warm Up Part II 24
dik
CA
For earlier thread, see
thread1618-496010
IR, dik, you write us off as denialists. But, we think your policies are going to make it worse. We don't like being flooded with daily observations of temperature because they're being used to drum up fear. Fear makes us do irrational things like scrap our energy grid in favor of one that will make things worse both economically and environmentally. That's why we roll out eyes at your sources and question their motivations.
dik said:
The key word is climate change... some places will get warmer, some will get colder.
So which is it? Are some places getting warmer and some getting colder (i.e. the bell curve is widening), or is the bell curve shifting in the warming direction, as per RVAMeche's chart:
RVAMeche said:
IRStuff said:
It's doing both, the mean is moving up, and the extremes are getting more extreme
RVAMeche's graph does not show an increase in places getting colder. The graph shows a reduction at the cold end. Is the graph wrong?
Does insulating your house increase the extremes of temperature from one room to the next? There is zero evidence that greenhouse gasses will make climate more extreme. The opposite should happen. With even temperatures we will not see the barometric variations that drive our storms. Extreme weather is just a cop-out when the models don't work.
Posting while making dinner. Maybe it was a bit too hot in the kitchen. Correction made.
Optimum? If we reach that we can only have decline afterwards. We should do our best to avoid this optimum.
His graph is of average temperatures over the globe, so no extreme temperatures are shown. Nevertheless, the distribution is broadening, so there are positions whose temperature differences are increasing, which implies a possibly greater heat flow between any given two points, which could imply more extreme highs or lows.
However, EPA reports fewer cold temperature extremes, relatively
TTFN (ta ta for now)
@tbe ... I don't think your analogy (comparing the earth's climate system to the inside of your house) is valid.
Yes we see this a lot in Australia. We were told for a long time the models are predicting hotter drier conditions. The local climate scientists told us we were entering permanent drought and desertification was underway on Australia's east coast. Then we get a run of cold wet conditions and they claim it's what the climate science has predicted all along.
It can be either... but the net result is that things will get warmer globally.
dik said some places will get colder (a common claim). That statement is inconsistent with the graph. The graph does not show any increase in places getting colder.
That took a little time... this time it will likely occur in our lifetime. Climate change will occur in decades, rather than millinnia.
rb1957, perhaps I should have compared it to a greenhouse? Do greenhouses have extreme varying temperatures within their enclosure?
I'll admit that there is an extreme variation but not in the way climate scientists would care to acknowledge.
Take a gander at AMOC... it is possible that Europe may become colder. We don't know where the pendulum will swing...
Given the presumption that significantly hotter temperatures are occurring as indicated by historic heatwaves in places like England, but only an average temperature anomaly of 2 degrees, then there must either be a lot of places with somewhat colder temperatures, or places with commensurately colder temperatures, ala "Polar Vortex" conditions.
@tbe .. no, greenhouses work completely differently to the atmosphere. They work, AFAIUI, but controlling the moisture inside the greenhouse.
greenhouses are not a good analogy for the atmosphere.
