Things are Starting to Warm Up Part II 24
dik
CA
For earlier thread, see
thread1618-496010
Yep, it is just DO SOMETHING!! Do anything.
Greg,
You say "think of the children" like it’s a bad thing.
What should we be thinking of instead?
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
I’m driving along the interstate and I sense a slight vibration. It’s not too bad so I carry on at the same speed, but the shaking gets worse. Since I am ignorant about vibration causes it shouldn’t concern me.
Should I follow the precautionary principle by reducing my speed, or blame it on gremlins and carry on like nothing bad could happen?
People aren't saying to gradually reduce speed. They're saying to slam on the brakes. Pretty good way to cause a highway pile up.
dik said:
tom... there is a wide gap of what I suspect strongly, and know for certain......I'm convinced that we have caused global changes, but I don't know what the end result will be.
I agree completely. We have burned a lot of fossil fuels, and there is a corresponding increase in atmospheric CO2. Barring some other explanation the extra CO2 is due to human emissions. There is a corresponding net increase in temperature of about 1 degree.
All that being said, it is unscientific to attribute cold weather to global warming and to pretend that the theory predicts an increase in cold weather too. Climate alarmists predicting hot weather and then pointing to a snow storm and saying "See! What did we tell you!" is why there is so much skepticism towards climate alarm.
The net effect is global warming. The name you should be using is Climate Change. The results can be unpredictable, but the end result will be climate change.
That's almost as silly as doing nothing... [pipe]
If Lake Mead drops another 100' it will no longer be able to produce electricity and if it drops 150' the Colorado will cease to flow... It currently provides water of 40million people, as well as the agriculture, and hydro for 1.3million people. What sort of cost benefit do you do for that? I don't know if it will happen, but there is the potential.
See the attached...
If that's the case, you might really start worrying... [pipe]
Yes I know the semantic games. It's been going going on since the 1980s. "Greenhouse effect" vs. "global warming" vs. "climate change". Not to mention all those people who feel that more exciting phrases like "Climate Crisis" and "Global heating" are the more appropriate terminology:
and things have changed in the last 4 decades, and not for the better...
Things are better in 2022 than what they said they'd be. Hence this new strategy of reframing statistically normal weather events as proof of climate disaster. Floods in 1900, 1910, 1940, 1950, 1980, 1990: NORMAL. The same size flood today: CLIMATE CHANGE.
I thought my analogy was pretty idiot proof, so it looks like I overestimated.
My mistake for insufficiently dumbing it down.
I think you’ll appreciate the dumbing down approach even more
How do you expect people to learn when you dumb everything down?
the problem with your analogy is that it is too simple. What's the cost of slowing down ? What's the cost of stopping ??
The cost of stopping burning FFs is enormous ... so much so that we don't mention it, although it is the appropriate precautionary measure if burning FFs is (maybe) going to cause the destruction of our environment. And some say that even this isn't enough.
Depending on the people, you may have to, and even slow down your typing so they can catch up. [pipe]
In what manner?
